1996 960 Transmission Trouble
Old Sep 2, 2007 | 05:47 PM
jmang09's Avatar
Default 1996 960 Transmission Trouble
Hello all
I am having transmission trouble with my 96 volvo 960 4 door sedan. When the car is first started, the transmission (AW30)will engage all gears and drive normally, however after heating up to normal operating temperature, the transmission will not engage any forward or reverse gears and go into nuetral even when the shift lever is in the drive (1 or 3 or L)position or reverse position. After turning the engine off and waiting 2-3 minutes and restarting the car, the transmission engages just fine till it goes back to operating tempature again and it goes back into nuetral mode. This all occured after I changed the fluid and filter (it was a dark brown and needed changing) Could it be the shift solieniod? Or is it the tranmission control module? or is it something far worse? I am having diffuctly understanding why this is happening and help is appreciated in any form. Thank you.
Rashad
Old Sep 2, 2007 | 06:11 PM
Default RE: 1996 960 Transmission Trouble
Is the transmission arrow flashing?
If not then the transmission might be going bad.
Old Sep 2, 2007 | 09:25 PM
jmang09's Avatar
no transmission light is flashing, any diagnostic testsyou know of I might be able to run? thanks.
Old Sep 2, 2007 | 09:34 PM
Best thing to do is take it to a transmission shop.
grodri1972
Jan 31, 2013 05:07 PM
krod407
Jun 30, 2011 10:15 AM
snoboarder_mike
Jun 15, 2011 07:39 PM
EMS
Jul 21, 2009 07:08 PM
hotrodcatie
May 28, 2009 07:02 AM
