1996 volvo misfiring 960
Old Sep 19, 2011 | 12:56 PM
charles61's Avatar
Default 1996 volvo misfiring 960
I have a 96 volvo 960 and the #2 cylinder is not firing its not the coil Ive switch it with one that works and theres power to the coil so what could it be thanks
Old Sep 19, 2011 | 04:21 PM
Have you pulled the plug? Also, make sure the wires in the coil plug are not backing out on you.
Old Sep 20, 2011 | 08:28 AM
dan550i's Avatar
If it still misses after checking on RSPI's suggestions, then you will have to swap the power stages, one is on the front of the intake and the other on the rear, swap them and see if the miss moves to an odd number cylinder.
When inspecting the wires, it seems that when the insulation gets hard, the wire can break inside and the insulation will look fine. But because the insulation is hard, it cannot take any flexing of the wire without break internally.
Sequence of checks, inspect carefully wires powering coil, inspect spark plug, move coil to another cylinder( you did that already), swap power stages, do a compression test.
DanR '94 964 360,000 miles (126,000 on the new engine)
Maulsby
Apr 26, 2019 08:14 AM
drizzledazzle
Oct 11, 2007 02:39 PM
OHVolvo
Oct 1, 2006 06:48 AM
