89 760 trans type.....
Old Aug 9, 2007 | 11:03 AM
Lxtasy's Avatar
Default 89 760 trans type.....
I just got an 89 Volvo 760 Turbo.The trans. is bad and I have 2 options for a replacement, one with a crank sensor and one without a crank sensor, how do you go about checking for the correct one?
Thanks,
Chris
Old Aug 10, 2007 | 10:23 PM
Lxtasy's Avatar
Default RE: 89 760 trans type.....
Anyone know?
Old Aug 12, 2007 | 07:31 AM
Look down the back of the engine at the back of the Head.
If your car has a speed sensor it will be mounted in the top of the transmission where it meets the engine.
Also another way to tell is to look at the Dist. if it has an electrical plug the car doesn't have a speed sensor. If the Dist. only has the 4 spark plug wires and the one coil wire it has a speed sensor.
Edit here is a picture of an engine with a speed sensor.
Old Aug 12, 2007 | 06:46 PM
Lxtasy's Avatar
Thanks man.Whats up with that Mustang you have? Stock or modded? I have a 90 FHP Mustang now, have owned about 13 prior, lol.
Old Aug 12, 2007 | 09:21 PM
Lxtasy's Avatar
Well went out and checked and I have the non-sensor trans.Thats a huge bonus because I found one for it with 72,XXX for 300 bucks.Now the fun begins, do I have to drop the fuel tank to swap out the trans? It looks like the driveshaft is above it but its kinda low so I didnt bother to totally crawl under it.
Thanks,
Chris
nortons
Jan 29, 2012 10:44 PM
4422
Apr 3, 2010 04:29 PM
Esnyder
Nov 6, 2008 09:41 PM
shadowlord
Apr 8, 2008 08:37 PM
jollygoodgold
Jul 16, 2007 12:06 PM
