92 960 ticking from engine
Old Mar 6, 2012 | 06:27 PM
kc2mrg's Avatar
Default 92 960 ticking from engine
ok ok, last post for the day, i swear, but anyways, i got a ticking in the motor cold or hot, seems like a lifter tick (im a bmw mechanic, we see this all the time with our 6cyl motors) but i wasnt sure if this was a common issue with these or not, if it is, i dont want to replace them if its not necessary but i have no problem digging into it and getting down and dirty, i need a timing belt and water pump in it anyways, but id rather know if i should put the lifters in it when i have the belt off or is it gonna be a waste of my time.
thanks for any advice from you guys, oh and it has 273,000 miles on it and im using a 5w30 castrol syn oil (i get it for free from work) and a napa gold filter, and ive tried a quart of marvel mystery oil last oil service and it didnt do anything, i just want to renew this car back to its glory, it was neglected for a few years by previous owner and i got it from her for $300, couldnt pass it up
Old Mar 8, 2012 | 05:04 PM
gabyman97596's Avatar
If it were my case I would use 20W50 and replace a quart with Lucas oil treatment. But thats just me. Start with a good tune up: air filter, fuel filter, new sparks plugs and wires cap and rotor , idk if you have coil packs but if u dont then replace does, put some seafoam treatment in the engine oil and another one in the gas. You should start from there
Old Mar 8, 2012 | 10:21 PM
kc2mrg's Avatar
well i want to fix it the right way, i do have coil packs and have changed the fuel/air filters and spark plugs about 4,000 miles ago when i got the car, i have replaced one quart with the mystery oil which has helped on previous cars ive had but it didnt do anything. if something is worn out i would like to replace it, i kinda got this car as a project car to tinker with when im bored
mhaynes01
Aug 22, 2009 09:07 PM
dan2286
Jul 15, 2009 01:47 PM
Capo Cam
Feb 23, 2008 10:19 PM
rob180
Jul 5, 2007 05:20 PM
Viraaj
Nov 3, 2006 03:16 PM
