93 960 dash light trouble
Old Sep 9, 2009 | 08:19 PM
oli's Avatar
oli
Question 93 960 dash light trouble
with the headlights on there are no dash/radio lights, the fuel gauge is erratic, one turn indicator stays lit as well as the high beam indicator!!! help
Old Sep 13, 2009 | 05:05 PM
Sounds like you have more than 1 problem.
My 1st suspecion is that the ignition is going bad and is not allowing the key to return to the run position all the way. Try turning the key back a little after you start it to see if that works.
I had a turn indicator stuck on my 960 last week. I pulled the small panel in the trunk on the left side. The same side the fuel lines and power antenna runs down. The side floor panel is about the size of a tissue box. At the forward edge of that opening there is a bracket with a blue box clipped to it. That box it the control relay for your turn signals, etc. I gave mine one good wack and have not had a problem with it since .
lister99
Dec 28, 2012 10:46 PM
trs80
Jun 25, 2011 02:05 PM
jonnyt2010
Feb 23, 2009 02:06 PM
tr_car_nut
Jan 19, 2008 09:37 AM
