'96 960 - Check engine light, no codes.
Old May 14, 2016 | 06:42 PM
patq911's Avatar
Unhappy '96 960 - Check engine light, no codes.
Hey there, I got a '96 960 in March and it's in super great shape, which is the only reason I would buy a car this old, but I'm running into my first annoyance.
I have a check engine light that turns on a few seconds after the car starts but there are no codes in the obd2 scanner, I bought my own, no codes, I brought it to autozone, no codes, and my mechanic doesn't get anything either. I even brought it to a volvo mechanic with a special scanner and he didn't get anything, saying it's the first time he's ever(!) seen that happen.
I've also tried disconnecting the battery for a few minutes but it came right back, with no codes.
The last code I had was a few weeks ago when it was still below freezing, my PNP switch was tripping the check engine and flashing "winter mode" arrow. I had my mechanic clear it a few times when one day the flashing arrow went away, but not the check engine light, and a few more weeks later it's still on and nothing I can do will clear it.
Soon I am planning on changing the timing belt and maybe I should also do the PNP switch to see if it will clear it, but in the mean time does anyone know anything about this? I don't want to scan it every week to see if anything REAL actually needs the check engine light.
Old May 15, 2016 | 11:29 AM
lev's Avatar
lev
Tough one! CELs are sometimes known to do this and it's "just" an electrical malfunction and it is understandably annoying... It's basically a short in the system but finding it could be time consuming and costly. Sorry, no good answer for that one!
Old May 15, 2016 | 11:34 AM
patq911's Avatar
I'm by no means an expert, or even know anything. but wouldn't a short of some sort have the light on always? Mine takes a few moments (10ish seconds) to turn on after you turn the car on.
Old May 16, 2016 | 09:41 AM
lev's Avatar
lev
Electrical shorts are impossible to predict how they will manifest themselves in the complicated automotive jumble--it could be anything, from a bad ECU to a slight wire chafing or a cracked solder on the back of the circuit board. You can try auto electrical shops to find a solution, sometimes they are able to find things quickly.
Old May 16, 2016 | 11:19 PM
VDonkey's Avatar
In my 98 the broken PNP switch set a fault code and made the CEL come on. I don't know if the fault code for the PNP switch was a new thing in the 98 motronic or not.
Old May 17, 2016 | 12:04 AM
patq911's Avatar
I had the code for the pnp a few weeks ago, I cleared it a few times because I knew it wasn't a huge deal, I just wanted the engine light to turn off. But the strange thing is now I don't get a PNP fault code, but just the check engine light.
Like I said I'll replace the PNP soon (a few weeks still probably) and post here if that fixed it or not.
Old May 17, 2016 | 08:13 AM
southpaw47's Avatar
My '95 960 Wagon check engine and SRS lights have been on for years. Too bad I can't use my OBD II reader rather than the archaic prehistoric flashing light port system. Neither condition has caused any performance issues, so I will continue to ignore. It's basically a 3rd car hauler but I am curious as to what the condition is.
Old May 18, 2016 | 06:58 PM
VDonkey's Avatar
I just remembered that in some situations the transmission can request the check engine light to come on. Maybe there is a fault code stored in the transmission.
VOL-FCR can read this but there might be a flashing light method too.
Old May 26, 2019 | 11:40 AM
jayvee's Avatar
Wow, same thing on my 1992 960 sedan. I've had ZERO issues yet the engine light keeps staying on.
burberry
Sep 4, 2014 09:08 AM
MainerInMitten
Nov 1, 2012 07:15 AM
96_960
Mar 3, 2008 02:21 PM
Wifeys1998XC70
Sep 21, 2007 06:08 PM
ekolaendzi
Feb 26, 2007 10:06 PM
