960 1992 B6304G - Relay problem, engine stalls.
Hi everyone.
I am new to this forum, I've been searching all thorughout the internet for these two relays, but i can't find out what they are. On pic attached, relay A gets very hot and engine stops working. Unfortunately, the relays I have on my car (A and B) are not the original, I have two Bosch 12V 30 amp relays. I want to know what are the specs of these two relays, so I can fix my stalling engine problem. I guess the relays are the problems, because after changing these relays to new 30 amp ones, the car works fine for a while, but as relays get hot the engine starts failing again.
Thanks in advance!
R
[IMG]local://upfiles/20781/71E153E866E54CAE95A311765F039C70.jpg[/IMG]
Thanks in advance!
R
Hi tech, TIPSP,
I havent been able to find the oem part number or relay specs( pin numbers, amp) for the ignition coil relay. I found out the specs of the main relay though (12V 50 amp 4 pins).
When engine shuts down while driving, I get these error codes:
Motronic 1.8
113 - Injectors group 1 faulty signal
115 - Injectors group 2 faulty signal
I hope chnaging the relays will help, or do you suggest anything else?
Thanks!
Motronic 1.8
Thanks!
Ok, I found out info on the relay. Thanks anyway!
I am going to try first changing both relays (the main relay and the ignition) and see if things get better, then Ill see if I change both
power stages.. cause I think each costs 180 dollars. I guess I would have to change both of them if i am getting error codes on both injector groups (1,3,5 and 2,4,6).
Let you know how it went.
Your help is really appreciated!
mtsumedi
11-13-2010 08:16 PM
