960 Inner Tie Rod End Replacement Questions . . .
Old Nov 21, 2019 | 04:34 PM
Cubic_Curiosity's Avatar
Default 960 Inner Tie Rod End Replacement Questions . . .
Greetings.
Need help identifying the correct procedure for replacing an inner tie rod end on the '95 960. Have a light clunk coming from that assembly; and straight-line tracking is off (periodic wandering/pulling).
Context: The car seems to have a common TRW rack.
First question -- Does the the steering ram on this model/year require a holding device to prevent damage to the steering gear or seal during inner tie rod removal and replacement?
Next, can a standard combination wrench be used to loosen the tie rod socket from the steering ram, or is this part recessed into the steering gear housing necessitating use of a special tool?
Finally, is the tie rod socket stud staked, setscrewed, or just threadlocked into place?
Looking carefully before I leap. I'll just farm it out to a local shop if there are any gotchas which require either gorilla-level strength or represent a threat to the rack from the application of tightening/loosening torque to the steering ram or seal.
Thanks for the input!
Old Nov 21, 2019 | 05:08 PM
Check out volvotips.com for a repair manual
Old Nov 21, 2019 | 05:28 PM
@mt6127:
Already checked Volvo Tips: 94 (not 95) 960 info for the old 740-style front end assembly; no inner tie rod procedures at all...
Old Nov 21, 2019 | 06:03 PM
@LussiRaw:
+1
Old Nov 21, 2019 | 07:28 PM
lev's Avatar
lev
https://www.brickboard.com/FAQ/700-9...RodReplacement
Old Nov 22, 2019 | 07:58 AM
Lev, that's a broad-sweeping general reference which doesn't cover anything in particular related to the TRW/960 arrangement. I cannot afford to experiment with this. I need clear, direct info on my end to determine whether or not I should even start the work, if anyone here has experience with this particular car/rack configuration...
From the OP:
In sum, does anyone have direct experience with this car/rack (or the relevant VADIS info) they would like to share?
Thank you again --
Old Nov 22, 2019 | 05:35 PM
lev's Avatar
lev
Well, I have done 940s and I am pretty sure the front suspension is the same. The instructions from that site are pretty good, I certainly can't do any better trying to guide you through...
vpatrol
Sep 24, 2011 01:27 PM
jigen3
Mar 2, 2011 02:45 AM
lowegroup
Nov 7, 2010 05:15 PM
ricbelley
Oct 26, 2009 05:30 AM
benithegreat
Jul 8, 2008 01:44 PM
