960 Mass Air Sensor
Old Dec 11, 2018 | 07:31 PM
volvonewb97's Avatar
Default 960 Mass Air Sensor
So I got someone to figure out what my check engine light was all about, and apparently the mass air sensor needs replacing. Is the car still driveable as is?
Old Dec 12, 2018 | 08:44 PM
well, how does it drive? If it drives normal or gets you from A to B ie - starts, idles correctly and you have full power then it may not be the MAF. Sometimes the CEL codes can be caused by a simple intake air leak or a dirty throttle body or idle air value can set the same codes. If the car has some stumbles but drives normal at other times, then you may want to start with cleaning the intake including the MAF, idle valve, throttle body using something like CRC MAF cleaner - not carb cleaner which can damage the filaments in the MAF.
barefootstomp
Oct 7, 2018 01:10 PM
Benjamin Smith
2001-2013 model year V70
Mar 5, 2017 03:02 PM
malcolm2
Sep 11, 2016 08:01 PM
betsycam
Oct 14, 2015 10:38 PM
tenacex
Jun 12, 2015 08:13 AM
