960 P0740 code
Sorry I was at a dinner for work.
That should work.
I also just thought of something else to look at but it is outside.
On the site of the tranny there is 3 plugs inspect then really good. The insulation on the wires for the female connectors fall apart and the wires will back out.
That should work.
Well, it is full (I think) and it shifts ok. It still kind of hesitates going from 1st into 2nd, but it doesn't jerk. It took a little over 3 quarts to fill, but I had the pan off for about 24 hours. I have the rest of the gallon in the car, so I will check it when I get to work tomorrow. I called Permatex today, and they said that it should work since I let it set for more than 24 hours before I refilled it. Time will tell. I noticed that the rpms were a little lower. It used to run about 2500 rpms at 65, tonight it ran about 2000 rpms.
Ok, so I got about 3/4 of the way to work and the cel came on. Guess which code it was? Thats right P0740. I am wondering if it is the computer getting hot and opening a circuit or something. Where is the computer? Is it next to the steering column or somewhere else? I turned off the heat on the way home, and it didn't come on, so I am thinking the heat blowing on it caused the problem (or exposed the problem).
How do I fix them if they have come loose? And the funny thing I forgot to mention is that when I cleared it this morning, it came back on with the car idling in park. I wouldn't think that the torque converter clutch would be kicking in that case.
It won't kick in idling but it might be the wires.
You can buy wires from the Dealer and cut the old ends off and either solder ot but connect the new ones on.
If you want I will try to get the part# of them and geive it to you.
So, I got it scanned at the transmission shop and they can't tell me what is wrong specifically without tearing it apart. It shifts ok except for from 1st to 2nd, and they said it seems like everything is working ok given the mileage. Oh yeah, then there is the transmission light/cel combo. I am seriously considering getting a computer from Ebay for $50 and see if it fixes it. Or maybe I should see if some C4 will help. Could it be related to my intermittent climate control issue where I lose damper control and it kicks out the code for the EGR valve. All vacuum operated I think??
Well, I got rid of ityesterday at the lot where I originally bought it. He has a junkyard also, and thinks he can steal a wiring harness from a Lexus GS300 to fit it. iI got a 2006.5 Kia Optima with 18k on it (time to start the clock over again). Hopefully no repairs in the near future!
