960 running on 5 cylinders only
Hello All ! Looks Like a great forum here
I just autozone scanned our "96" 960 and I received the following:
1) P0410 Secondary air injection sys malfunction
2) P0118 engine coolant temp circuit high input
3) P0304 Cylinder 4 misfire detected
I would like to fix Number 3 first.
Any advice and direction would be much appreciated !
Thanx !
Thanx !
There should be a fuse or relay in the fuse box under the hood for the fuel pump.If it is easier swap 4 and 1 or something like that and see if the code changes cylinders.That would be the easiest way to test it.I will bet it is not missfiring all the time.Only during acceleration when hot or something like that.
