960 Wont Start (1996)
Old Aug 9, 2014 | 02:26 PM
jimmymaclists's Avatar
Default 960 Wont Start (1996)
Seemed to be running fine and was stopped at a stop light. When light changed I accelerated but the engine cut-off immediately and would not re-start.
Cranks but wont start.
What I have done since:
- Checked spark -spark was dim
- Replace spark plugs & fuel filter (just did it since I didn't know when they were changed last)
- When key is turned on I do hear the fuel pump turn on
- Checked fuses & relay's
- Fuel Shrader valve on back of fuel rail - removed cover and pressed valve, fuel sprayed out
- White/Red connector at back of head - checked voltage with key on and only read .03 (basically nothing)
The items I've done above were done based on other posts I read here - so thanks for all the advice in the forum.
I'm thinking it could be crankshaft sensor - any thoughts?
Thanks in advance
Old Aug 9, 2014 | 10:35 PM
lev's Avatar
lev
Check the timing belt?
Old Aug 10, 2014 | 07:16 AM
I did pull the cover off and the timing belt looks good. Car has 160000 miles on it and the bely was replaced at 145000
Old Aug 12, 2014 | 09:46 AM
lev's Avatar
lev
The CPS is definitely a possibility. I'm not into White Blocks very much, but if this was a Red Block, like a B230, the CPS would be on top of the list.
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
baltazar
Jun 20, 2012 09:18 AM
hoit666
May 23, 2009 01:28 AM
furball3
Jan 28, 2007 03:31 AM
