air con 960 1995 estate
Old Jul 17, 2010 | 06:04 AM
cookie2004's Avatar
Default air con 960 1995 estate
how cold should it be
Old Jul 27, 2010 | 12:52 AM
Joseph/TX's Avatar
Depends on outside temp and humidity, but if you are going down the road and getting an actual 38-45 degrees fahrenheit out of the center vent you will probably be comfortable. Those red pocket dial thermometers that you get at the auto parts store often vary 5-10 degrees, so it's hard to get an accurate reading. What they are good for is monitoring change. I keep one stuck in my vent all the time, solely for that purpose. To get the actual temperature out the vent I use a higher quality thermometer that I got at a liquor store, which is used to measure the temp of wine. It has better response time and a 0-120 degree scale, which I think is preferable to the 200 degree scale on the cheap ones. Bear in mind that if you get stuck in traffic on a hot day the air won't blow as cold as it does when you are going down the highway at 70 mph.
Old Jul 28, 2010 | 09:01 PM
When the ac place is charging my car, their goal is 54 degrees.
Celebrationman
Jul 29, 2010 04:36 PM
dixie212
Apr 15, 2008 01:14 PM
outblast
Jan 1, 2008 01:52 PM
gullyg
Jul 30, 2006 09:14 PM
wojeepster
Oct 7, 2005 11:38 PM
