Feeble Air Con on 95 850 T5
Old Jul 18, 2006 | 05:41 AM
gullyg's Avatar
Default Feeble Air Con on 95 850 T5
Hi,
The climate control on my t5 does produce cold air, it just doesn't seem to produce that much of it especially when it's been running for a long time (6hrs etc).
The AC and REC lights flash for about 20secs when I start the engine but then go off. From what I've read this is an error code however I spoke to the dealer and they say it's working perfectly.
I really must change dealers (I don't use them normally but use a friend's garage instead) as they can't track down the cause of a fault light and also told me the extendable aerial shouldn't retract all the way into the car.
Does anyone have any ideas?
Cheers
Iain
Old Jul 18, 2006 | 02:46 PM
code33's Avatar
Default RE: Feeble Air Con on 95 850 T5
On the '95, you can pull the codes yourself from the B-side of the diagnostic. That will tell you why the AC & REC lights blink.
http://www.volvospeed.com/CheckEngine.php
Old Jul 22, 2006 | 07:02 AM
gullyg's Avatar
Cheers - I'll have a look when I get my car back from the dealer (lambda sensor problem).
Old Jul 30, 2006 | 07:54 AM
gullyg's Avatar
This might be a stupid question but where is the diag box. I'm looked in the ecu housing but I can't see anything that looks like it.
The haynes only refers to cars 96 and onwards.
Old Jul 30, 2006 | 12:02 PM
If your 1995 has the OBDI it would be on the front of the Box right next to the Washer fluid fill.
Old Jul 30, 2006 | 02:36 PM
gullyg's Avatar
Cheers for the reply - I think I looked there as well, there is a box but it merely contains a load of wires which look like they go into the bottom of the ecu housing.
The Haynes says that for 96 onwards there should be a plug in that very position for some sort of diag tools but theres not that either.
Old Jul 30, 2006 | 03:10 PM
It would be there for 93,94,and early 95's 96 and one is in the Center console in the car. Next to the Cigar lighter. That is OBDII
Old Jul 30, 2006 | 07:04 PM
gullyg's Avatar
I don't know when my car was produced - I know it was registered some time in 95, I'll see if I can dig out the V5c tomorrow.
I take it I have to remove some of the facia to get to it if it's next to the cigarette lighter? Will I still be able to read the codes without extra equipment.
I can follow a haynes for fairly simple stuff but tbh I'm not very mechanically minded. The problem is that ontop of me not having any money at the moment the stealer (sorry dealer) isn't interested.
The weird thing is that Haynes puts the plug for a reader next to the washer topup and I've been told here and found it in other places that the box is there on the earlier cars however on my there is nothing but wires.
I'll have another scout around the internet and see if I can post a pic tomorrow.
Many thanks
Iain
Old Jul 30, 2006 | 09:14 PM
You will need a scanner to pull the codes properly.
arzy
Feb 13, 2009 06:39 PM
arzy
Sep 15, 2008 12:30 PM
dixie212
Apr 15, 2008 01:14 PM
outblast
Jan 1, 2008 01:52 PM
wojeepster
Oct 7, 2005 11:38 PM
