Back seat door carpet install
Old May 29, 2023 | 09:25 AM
Tom K's Avatar
Default Back seat door carpet install
Do I pop those plastic things out of the door and get new ones? I've given up trying to slide it on to those existing plastic things.
Old May 29, 2023 | 10:37 AM
PeteMohr's Avatar
Sometimes (but rarely) you can get them out and reuse them.
I'd just go get some new ones.
This kit probably has some you can use:
Amazon Amazon
Old May 30, 2023 | 09:18 AM
va740twagon's Avatar
That is funny. It looks impossible, even with new pins, since one of the mounting points on the back side of the carpet panel has a slot that points to the side in one direction, and the other two mounting points have slots that point in the opposite direction. It looks like a cruel joke on the part of the designer. How does a person slide the panel to one side and lock onto two of the pins, and then slide the other direction somehow and get it to click on the other pin without unlocking the first two pins?
Old May 30, 2023 | 10:08 AM
PeteMohr's Avatar
Originally Posted by va740twagon
That is funny. It looks impossible, How does a person slide the panel to one side and lock onto two of the pins, and then slide the other direction
You don't slide the panel.
You put the pins in the panel first then snap it in place.
Old May 30, 2023 | 06:38 PM
Tom K's Avatar
Thanks I'll buy that kit.
AT5 240GL
Oct 26, 2014 02:58 PM
AlanS
Nov 18, 2010 09:12 PM
animedragonfighter
May 1, 2010 12:49 AM
zerochills
Dec 27, 2007 01:53 PM
bansaw
Sep 10, 2007 10:12 PM
