How do I install a driver's door?
Old Nov 18, 2010 | 08:42 PM
AlanS's Avatar
Default How do I install a driver's door?
I got a used drivers door for my 95-850. Current one is all rusted. I am cautious about putting the new one on...I fear that once I get the old one off, the new one won't line up, etc. Any hints on dis-assembly and installation? I see that there is a rubber 'umbilical' from the door jam to the door. How does this get removed? etc.....I would like to do it before the weather turns.
I don't want to land up with a whistling door, or one that scrapes because it is mis-aligned.
Old Nov 18, 2010 | 09:12 PM
For the most part it should line up pretty good when you put it on.
For the wiring if you follow it close to the body you will see a plastic ring and a small torxes screw. Remove the screw and turn the ring to unplug the harness.
To swap the door if you look by the hinge you will see an inverted torxes screw on each hinge. Remove the 2 screws and lift the door off and swap them out.
Lgbpop
May 26, 2021 03:34 PM
Exer
May 10, 2015 01:15 PM
Newport_j
Oct 18, 2014 03:55 PM
daver80
Mar 2, 2013 03:09 PM
wildcard442
Apr 11, 2010 09:12 PM
