1996 960 wagon - climate control pushing out air upon start up
Old Jun 8, 2023 | 12:00 PM
davidrandall's Avatar
Question 1996 960 wagon - climate control pushing out air upon start up
Upon starting the car (cold start each morning and occasionally throughout day) either while turning the key in the ignition partway and/or all the way - there is first a few seconds where the climate control system (which is in the off position) pushes and releases a gush of air through the vents. After a few seconds this air stops coming out of the vents and you can set/adjust the climate control system to whatever setting you want. What is causing this issue, what recommendations to fix it...and any other issues this problem will trigger in terms of additional needed repairs? Thank you.
Old Jun 8, 2023 | 03:04 PM
sounds like the ECC needs a few seconds to set the blower resistor to a low speed. If I recall correctly, no signal to the resistor sets it to full on...
Colby.antico
Aug 26, 2022 09:00 PM
CoKroVolvo
Feb 12, 2022 04:31 PM
skadet
Mar 30, 2009 11:18 PM
madador
Dec 16, 2008 11:43 AM
CobraO
Jun 23, 2008 11:36 PM
