brake problem...
Old Jul 25, 2008 | 10:17 PM
kzs983's Avatar
Default brake problem...
I was changing the rear rotors and pads on my 96 960 and the slider pin is for the caliper is stuck, its the top one on both. do i need to buy a whole new bracket or is it possible to fix/free this? anyone else had this problem, and what do you suggest i do?
Old Aug 5, 2008 | 02:43 PM
4ofHearts's Avatar
Default RE: brake problem...
If I remember right you should just be able to unscrew it from the back...and remove it... I think when I ran into the same problem, I had to use a hammer and pound it in and then remove it a few times. I regreased it and it was fine after that.
s70_t5_1999
Jan 22, 2010 11:53 PM
MaZoN
Aug 5, 2008 06:52 PM
thullz
Nov 7, 2006 09:25 AM
mywifescar
Jan 13, 2006 12:59 PM
