Broken Trunk Latch??
Old 08-06-2014, 02:29 PM
Haymaker17's Avatar
Default Broken Trunk Latch??
My trunk lid will not open. Is there a way to access the trunk or a suggestion as to how I can open it. The key seems to unlock the trunk but the latch does not seem to be catching anything and it will not open. I thought that I might be able to access by removing the back seats but that was not the case. Any suggestions??? Thanks!
Old 08-06-2014, 09:29 PM
lev's Avatar
lev
lev is offline
from brickboard.com
940/960 Cars.
[Tip from Tony Diamond] The usual problem is that the lock control arm, extending from the lock cylinder to the lock itself, has come loose. This is unfortunately covered by the plastic boot trim and is not accessible through the ski hatch opening. You can try two approaches. Easy, risk free: remove the rear seat, climb into the trunk, remove the trim, and repair the lock. Brute Force: A friend with the same car allowed me to dismantle the trim in the trunk to see what was inside. I measured the position of the arm in relation to the rear panel, I then drilled a hole behind the rear number plate and was able to recover the loose end of the control arm with a wire coat hanger and then tugged it open with a pair of long nosed grips. The hole was 25mm and was treated and sealed with a rubber grommet and is unseen under the number plate.
RrCoX22
09-01-2020 10:06 AM
Methuselah
08-14-2010 12:55 PM
metallisch
06-24-2009 09:13 PM
timalabim
11-27-2008 02:01 AM
pstrnfls
02-18-2007 05:03 PM
Quick Reply: Broken Trunk Latch??
