Can't clear check engine light
Old Feb 25, 2021 | 07:49 PM
Chitownrojo's Avatar
Default Can't clear check engine light
I can't clear the check engine light.
traction control won't disengage.
But considering the car's been sitting for 3 years I'm not surprised any thoughts please thank you.
It's a 96 body and the engine is junkyard.
I'm thinking it's a corrosion on the switches from setting for the past few years.
Old Feb 25, 2021 | 08:23 PM
lev's Avatar
lev
CEL should clear by disconnecting the battery for 1 minute unless there is a major malfunction which triggers it immediately after the reset.
Old Feb 26, 2021 | 07:02 AM
What year and model car? sorry looking thru your posts you have been asking about a 96 960 you put a 95 engine in.
To clear the check engine light connect a compatible scan tool to the obd port between the seats - read the codes then erase them. Drive and see which ones come back.
"Traction control won't disengage" - can you explain that a little further? Do you have a warning light on the dash? Are you referring to the transmission winter mode?
Old Feb 28, 2021 | 08:14 PM
Got the traction system to disengage turns out it wasn't plugged into the fuse box.
check engine light still on computer still not reading?
Old Mar 1, 2021 | 12:37 PM
Do you have one of these ports near your left strut tower under the hood? If so that's where you read /erase codes and you have a 1995 or earlier car.
Old Mar 1, 2021 | 07:43 PM
It's a 96 got a better code reader it pulled a tps code and 3 transmission codes.
mpower916
Apr 27, 2011 11:37 PM
cbaxter1988
Aug 29, 2009 12:22 PM
jetfire
Jul 26, 2009 05:41 PM
llama_of_doom
Aug 23, 2007 09:52 PM
cool_kyle_3000
Jun 7, 2006 12:14 AM
