Considering a 1995 or 1994 960 sedan
Under the 240 board I posted that my 1990 240 was in a crash, and I am looking to replace it. Under consideration is a
1995 960 with 125k miles
1994 960 with 185k miles
Any thoughts on the reliability and quality of these cars? Ideally I would have replaced my 240 with another, but it is hard to find one in decent shape, without over 250k miles, and post-1990 when they introduced the airbag to the car.
Thanks in advance!
Thanks in advance!
If you purchase this car be aware of the timing belt change for these engines.
They are interference engines and a broken timing belt can break valves and damage pistons in a catastrophic way.
I think in 1995 timing belt change interval was 50,000 miles. Someone will correct or verify this.
They are great cars I have a 1997 965, great road car. IF you buy it try and find out when the timing belt was last replaced, if it can't be determined I would change it. When mine was replaced I did the water pump and tensioner also.
Good luck
Good luck
I have heard that some 1992-1995 engines had porous blocks, i.e. manufacturing defects in the block. You can read about it here http://www.brickboard.com/FAQ/700-90...960B6304Blocks
