INNOVA OBDII 3100 check 1996, 960
Old Jul 15, 2006 | 07:21 PM
TheVolvoMan's Avatar
Default INNOVA OBDII 3100 check 1996, 960
I was driving on a freeway earlier today. w/o warning, my power streeting stopped functioning (No fluid lose). Then almost all warning lights on Dashboard were on. However the car kept running fine. All gueges (speedometer, Tachameter, Temerature and fuel) seemed to work fine. Including the turn signals.
At home, I tried to check the engine with INNOVA OBDII 3100 Digital Code Reader, it would not spit any error codes on the display.
Any observations or suggestions please
thanks
Old Jul 15, 2006 | 07:41 PM
Default RE: INNOVA OBDII 3100 check 1996, 960
The drive belt didn't come off did it?
Was it raining?
Old Jul 15, 2006 | 08:12 PM
YES mister angle. It did come off. Literallt was shredded. Funny I checked under the hood and for somereason missed it.
Mucho Much grassias my good man
Old Jul 15, 2006 | 08:17 PM
In a way you are REALLY LUCKY Alot of times when the belt breaks it gets sucked into the Timing belt and breals that to causing critical damage to the engine.
Old Jul 15, 2006 | 08:19 PM
Particularly when you are 75 Miles away from home. In a 95 dgree CA heat.
thanks again.
Now I am looking for a post how to install the new one.
Old Jul 15, 2006 | 08:41 PM
It is pretty easy to install. It should go around the Crank then up and around the alt then around the idler then the power steering pump under the tensioner and thats it.
It might also go alittle different by the Alt. depending on the belt size.
Old Jul 16, 2006 | 12:37 AM
I will sure ask my Volvo garage to give me a diagram, just in case.
All the best.
dave9170
Sep 5, 2011 11:37 AM
ikes4ever
Mar 25, 2010 07:25 PM
jwardmls
Nov 9, 2008 08:30 PM
Eple
Aug 30, 2008 06:05 PM
lister99
Jul 15, 2008 08:14 AM
