Only left side parking brake shoe moves
Old Aug 23, 2013 | 07:48 PM
manoduv's Avatar
Default Only left side parking brake shoe moves
My parking brake barely grabs. Tested it by pulling the handle with the rotor off and only the left side moves, and barely. If I remember correctly, it is the left side on both sides. Is this a frozen cable or could it be frozen in the assembly somewhere? Is there anyway to test the cable before replacing it?
Old Aug 23, 2013 | 08:42 PM
97-850Wagen's Avatar
Find the cable where it goes into the sleeve and spray it with some PB Blaster. Let sit, and repeat. If it starts moving a bit easier afterwards, the cable was/is frozen. Also check to make sure it is adjusted properly. Replace as necessary
Old Aug 25, 2013 | 11:25 PM
If you leave one side with the rotor in place and check the other it will let you know. If you pull both rotors then the one that moves the easiest will do all the work.
It's most likely a rusted up cable but you need to physically move the shoes around to make sure they are still "floating" on the backing place and able to expand if you have a working cable.
https://volvoforums.com/forum/volvo-...ustment-43292/
http://www.matthewsvolvosite.com/for...php?f=1&t=2927
http://www.matthewsvolvosite.com/for...hp?f=1&t=29623
Old Aug 25, 2013 | 11:43 PM
Curious about that first link, removing the center console: In my car (97 wagon), if I open the arm rest there is a removable panel in the bottom of the storage box towards the front. Removing this reveals what looks to be the adjustment screw for the ebrake handle (looks like a t47 or so silver bolt). Is this correct? It looks as if there is enough room to get a socket in there without removing the full console...
Old Aug 26, 2013 | 01:05 PM
manoduv's Avatar
That's correct
Old Aug 26, 2013 | 01:15 PM
Originally Posted by manoduv
That's correct
Thought so Starting to love the simplistic engineering of these cars more and more every day
ScottyJ
Nov 15, 2013 12:40 AM
jdbs3
Oct 20, 2011 05:06 PM
rspi
Apr 4, 2009 09:15 AM
usedS70
Jun 26, 2008 10:26 PM
