Small Coolant Leak
Small Coolant Leak
Hey, I have a 1996 960 with approximately 88,000 miles. I noticed some coolant on the ground below my car yesterday and took a look under the hood. I found that coolant it is slowly leaking out from where the hose (that connects the radiator to the thermostat housing) connects to the radiator. I tried tightening the hose clamp but it wouldn't move. I am assuming the hose is just old and needs to be replaced but am wondering if you think it could be something else.
Thanks,
Tom
Thanks,
Tom
RE: Small Coolant Leak
I checked this out today and the plastic pipe that the hose connects to on the radiator is cracked. Is there any way to fix this crack or do I have to replace the whole radiator? Replacing the whole thing would stink because the radiator itself still works perfectly fine. Thanks for your help.
