Trouble starting after accident
Old May 22, 2013 | 12:02 PM
Spalding's Avatar
Default Trouble starting after accident
97 excellent condition 960 - 115,000 miles
Car was in a minor front end collision. Engine started up just fine afterwards for a few days. A few weeks later the engine just turns over but doesn't fire. I've removed everything from the front of the car and inspected the timing belt. I can't seem to find anything wrong with anything yet.
Anyone know where to look next?
Any help is greatly appreciated.
Old May 22, 2013 | 02:39 PM
danr960's Avatar
Air, fuel, spark all that should be needed. Assuming the front end of the engine did not take a hit, so the timing is unchanged. If you have the timing belt front cover off, check the marks, all of them are just too hard to find, but if you have the cover off try to figure that out.
If the cover is not off yet, then check for spark, remove the black and silver volvo cover and remove one coil and spark plug. Place coil back on removed spark plug and ground the base of the spark plug to the engine. Crank over and have someone look for a good solid spark. If spark is confirmed, go to a big brand auto parts store and have them loan you a fuel pressure gauge, check fuel pressure when turn key to start, you might have to deplete the pressure first depending on how long it has been since it was last started, on initital start up, one the key is turned to the second position, the fuel pump pre pressurizes and then shuts off until the engine is running.
Check and see if there is any broken plastic clogging up the air ducting to the air filter, or in the air filter housing, never know what you might find in there after a hit.
Check fuses, maybe something tripped one.
DanR '94 964 385,000 miles (151,000 on the new engine)
Roden2007
Dec 16, 2010 07:17 AM
jdaniels30
Apr 30, 2010 03:11 PM
dpallen
Dec 4, 2008 05:29 PM
Kaybihiak
Dec 1, 2007 11:03 PM
EAS1
Jun 23, 2007 05:18 AM
