The V90. Rear suspension question
Old Apr 18, 2009 | 01:54 PM
Drew45's Avatar
Default The V90. Rear suspension question
Can someone advise me please!
Hi all.
My V90 rear seems to me to be very low.i.e on one side the clearance
from wheel arch to tyre is half an inch, the other side is about an
inch. I have Nivvomats. Do I need to replace both but I was wondering how difficult a job is it? I have never
done work on suspension but I have worked on engines so I do know one end of wrench from the other.
Is there anywhere a step by step guide for the V90 and also what kind of special equipment would I need that is not run of the mill.
I know for the early 900's it's not a hard or tricky job but what about the multi link Suspension volvo's.
Many thanks for any advice anyone can give.The year? 97!! .
Old Apr 18, 2009 | 09:15 PM
I would replace both they are not all that bad to replace.
Old May 11, 2009 | 09:37 AM
strutmaster's Avatar
I would recommend going to strutmasters.com and taking a look at the conversion kits. This converts you from air to powder coated, American made steel coil springs that are guaranteed to last the life of the car. The kit comes with detailed instructions including how to disarm the ride light. Everything you need will be in the kit. I posted the link below so you can take a look.
http://www.strutmasters.com/volvo-su...parts-s/35.htm
Good Luck!!!
martin calva
Apr 20, 2015 03:01 AM
martin calva
Apr 15, 2015 04:59 PM
kenm.10
Jan 21, 2012 12:15 AM
melancthon
Jan 1, 2011 06:08 PM
dtsol
May 11, 2009 09:47 AM
