Volvo engine needs help.
Hmm well I hadn't given it much thought untill you asked, it does not have a model number on the back end like most Volvo's (See picture). I guess it would be a 260, it has the B27 motor, 45,000 miles and except for the A/C compressor that was replaced in the 80's everything was original when a bought it (about 2003) even the tires. The tires came apart so they have been replaced and now the head gaskets are going to be replaced.
I almost have the left head cleaned up. The oil holes in the rocker-arms did not seem to be clogged. When I put them in the parts washer the cam oil holes sprayed out cleaner when pumped through the rocker-arm shaft. I have read that the holes in the rocker-arms that oil the cam were made larger on newer B28/B280 engines. I used gage pins and the holes in the left head are .032". Does anyone know if newer engines had larger holes if so what size are they?
nick2ny
11-09-2011 07:18 PM
graf101
06-03-2010 11:44 AM
FUSE77
11-27-2009 12:51 AM
