Wastegate
Old Jan 31, 2005 | 06:34 AM
wastegatecrazy's Avatar
Default Wastegate
Hello all,i have been trying to vent the external wastegate to atmosphere,rather than back into the inlet,as rather sadly,i would like to hear that wastegate working
but i have trouble with the car idleing/stalling,when the lower pipe of the wastegate is taken off.................any help would be appreciated,also,what about giving the boost a safe little tweak,any ideas???
thanks.
oh by the way its an f plate 760 turbo intercooler
Old Jan 31, 2005 | 09:59 AM
Default RE: Wastegate
If you want to hear noise buy a blowout Valve.That would be your best bet to be able to hear noise and won't cause and running problems.You can remove the wastegate valve and Adjust the rod then install it will give you a little more boost.You need to turn a little then reinstall and try then adjust again.You have to do it slowly so you don't go right into overboost.Usually 1 turn is the best to take it to.
Old Jan 31, 2005 | 10:32 AM
Thanks for reply,ive fitted a pipercross cone filter which had made it a little more audible,and regards to the wastegate,as its external,i shouldnt need to take it off should i,just adjust the nut on top of the unit?
Old Jan 31, 2005 | 10:53 AM
You should have to remove the clip and take the rod off the waste gate to turn the end cap peice that attaches to the waste gate.You cannot turn the rod itself or you will risk ripping the diaphram for the wastegate valve.If you get a blowout valve it will sound a little louder depending on which one you buy.A buddy of mine had a huge one he put on his 740 and it scared people when it kicked in it was so loud.
Old Jan 31, 2005 | 11:03 AM
Think we are getting our wires crossed,when i say its external,its seperate,as in not attached to the turbo,it sits just behind the intercooler/radiator,by the waterpump..............
Old Jan 31, 2005 | 11:16 AM
Ok now I got you.
Do you have a picture of it?I like seeing things people come up with.
Old Jan 31, 2005 | 11:21 AM
These are some pics of my buddy's car.
[IMG]local://upfiles/853/A261AE88ABAB434B81A04DCEAA8461AC.jpg[/IMG]
[IMG]local://upfiles/853/2B46F1D64CEB4862880F896A368D1183.jpg[/IMG]
Old Jan 31, 2005 | 11:38 AM
Havent got a pick to hand,its a standard volvo thing,nothing aftermarket,your buddys engine bay looks good!what sort of power has that got?
Old Jan 31, 2005 | 12:03 PM
He didn't tell me HP #'s but with the nitrous he ran 13.50 in the 1/4 mile.He wasn't really happy with it then.He is in the process of building a carbrated Chevy 350 making pretty big HP to drop into it.
ENDEE666
Jan 29, 2024 01:33 PM
pigtown*design
May 23, 2009 12:17 PM
240maybe
Jul 30, 2007 12:03 AM
tcrossley
May 20, 2006 12:50 AM
t5killer
Sep 26, 2005 09:31 AM
