What other steering wheels fit a '93 960?
Old Jun 27, 2012 | 12:11 PM
moorepower's Avatar
Default What other steering wheels fit a '93 960?
Hello all,
I need to replace the steering wheel and airbag in my '93 960 wagon due to horn problems and a deteriorating airbag, so I'm wondering what would be a direct bolt-in, plug and play option. I've read that an 850 wheel would work. Can someone confirm this, and does anyone know if a V70 or even a later 960 would work? I think they changed to the two-stage airbag somewhere around '98 maybe? So I don't think that would be compatible with the earlier setup.
Any insight would be greatly appreciated.
Old Jul 5, 2012 | 07:35 PM
pretty sure any 960 wheel will drop in and be an exact match. 940 interiors are different in enough ways that I wouldn't expect them to fit. IIRC, the 850/V70 uses a smaller diameter steering wheel
Old Jul 5, 2012 | 08:46 PM
Henry10's Avatar
Pierce is right. 960's steering wheels of all years will fit. Nothing else. See here.
"Deteriorating airbag" -- I assume you are talking aesthetically.
I am just curious -- why wouldn't you buy the airbag and clockspring from a JY? That should run you $ 70-80 for both.
It sounds to me that Clockspring is bad. That should be simple and cheap to get.
Old Jul 6, 2012 | 03:12 PM
moorepower's Avatar
The cover of the airbag is coming apart, and I'm not sure I trust the innards to work as intended in an accident. And now that the horn has started acting up, I thought it would be a good excuse to change everything out.
The local Pick-n-Pull sells airbags for $50 and wheels for $10, so I can get a matched set for $60 total. The problem is that they rarely have 960's, and if they do, they're always late models. But if a late model will bolt up and work, then that's the route I'll go. I think the late model steering wheels look better anyway.
Old Jul 6, 2012 | 04:34 PM
Henry10's Avatar
Dan: About replacing the airbag, I would follow the procedures in the SRS section of the Manual (deactivating SRS, activating, handling airbags, disposal); I am sure you know about it.
Old Jul 6, 2012 | 07:30 PM
moorepower's Avatar
Ah yes, I've read and re-read it about a hundred times. I have great respect for explosives.
Thanks for the reminder, though.
Old Jul 6, 2012 | 08:32 PM
fwiw, the updated model 960 (1996 only?) is identical to the S90/V90 (1997, 1998)
now... I don't know for sure if the steering wheel is interchangeable between those updated cars and the earlier 960s from 1992 to 1995.
bcolins
2001-2013 model year V70
Oct 21, 2013 03:09 AM
Danny Zuko
Jul 18, 2012 03:45 AM
RRTEC
Aug 18, 2009 03:30 PM
postdoc99
Sep 23, 2007 05:18 PM
jcmartin
Mar 3, 2005 12:02 AM
