'93 850, vibration, mostly in 1st & reverse
Old Aug 27, 2010 | 06:02 PM
danielcash's Avatar
Default '93 850, vibration, mostly in 1st & reverse
1993 850 glt 5 speed. Just bought, knowing of vibration. Mild to moderate vibration in 1st and reverse, while departing. (while engaging clutch) Can easily finesse my way around it, especially in 1st. Compensating for it with throttle and clutch balancing is second nature now, but it is definitely a symptom. It is more prevalent in reverse. it is not violent or earth-shaking, it is mild to moderate. Tranny mounts? Tranny? Or: There is a clutch something-or-other that is there to reduce vibration to the cabin..... I can't remember what it's called(?) Any thoughts anyone? Thanks, Dan -Colorado
Old Aug 27, 2010 | 10:34 PM
Probably bad/worn mounts. Check them first.
Old Aug 27, 2010 | 10:44 PM
turbo matt's Avatar
I might be inclined to say your Flywheel is warped? Depending on how old the clutch is and if they turned/resurfaced when a clutch was put in. A Warped Flywheel will give the same type symptoms.
underaroof
Sep 6, 2013 09:35 AM
Pcar993
Dec 14, 2012 09:03 PM
dwbf1
Jul 3, 2011 02:04 PM
ocean238
Apr 17, 2008 06:20 PM
wufmama
Feb 20, 2006 11:44 PM
