1994 850 turbo
Old Dec 9, 2010 | 08:03 PM
OBETSKI's Avatar
Default 1994 850 turbo
Hi peeps. This is my first time buying a Volvo. It's a wagon 850 Turbo...what problem usually would I encounter with this car? Input please...the seller said that I just need to replace the inter-cooler and that's about it Anything else? It has 121,000 miles. Thank you in advance.
Old Feb 13, 2011 | 09:37 PM
JPN's Avatar
JPN
This thread should give you some ideas to get started:
https://volvoforums.com/forum/volvo-850-16/new-volvo-850-owners-read-important-thread-also-applies-s-v70s-9266/
Good luck,
JPN
Old Feb 14, 2011 | 01:04 AM
boxpin's Avatar
Replace the intercooler??? what kind of nonsense is that? Why did they say that? What is the actual problem that they are putting the death sentence on the intercooler? Unless they crashed into something its probably not the issue. Share more please, dont want to see you getting ripped off here. They better had a good reason.
Old Feb 14, 2011 | 11:09 PM
OBETSKI's Avatar
The seller said that it's overheating. So I assumed it's the head gasket. He said it runs good etc etc. and that there is a steam on the reservoir. He said theat his mechanic said that it is the intercooler.
Old Feb 15, 2011 | 01:09 AM
ibified's Avatar
then his mechanic is an idiot. An intercooler has NOTHING to do with overheating. if it's overheating, it could be the radiator, or head gasket, bad thermostat, etc...
I think I'd walk away from this car, because I have a feeling that the seller is lying to you about this. If he's lyingo to you about this, he could very well be lying about who knows what else. Find an honest seller.
Old Feb 16, 2011 | 01:26 AM
JPN's Avatar
JPN
If your head gasket is shot, you would see:
- Loss of compression (have it compression tested)
- Loss of coolant (keep an eye on the reservoir or have it pressure-tested)
- Oily coolant in the reservoir
- Sweet odor from the tail pipe
- Emulsified engine oil (very often, this is normal on 850s and is due to condensation)
JPN
Keith Tobberman
Nov 7, 2007 09:35 PM
ajtrem
Jan 30, 2007 09:02 PM
steveHut2
Mar 10, 2006 08:56 PM
debcosta
Nov 27, 2005 08:42 PM
