1995 850 glt heater controls mcs
Old Jan 1, 2008 | 12:47 PM
jds850's Avatar
Default 1995 850 glt heater controls mcs
I have great temp ranges on passanger side but no control on drivers side. I know that from looking at past threads it may be a cable either broken or come loose. If this is right how do I get in there to check either one of these conditions or if it is another problem what do I check.
Thanks,
J
Old Jan 1, 2008 | 12:50 PM
Default RE: 1995 850 glt heater controls mcs
Remove the lower dash panel and look up and find the cable and see if it moves with the ****.
Old Jan 1, 2008 | 12:58 PM
jds850's Avatar
Tech,
I am not sure I am doing the right thing. When I removed to lower part of the dash on both sides all I see is SRS black system so I dont think I am removing the right thing but I do not see anywhere else that can be removed.
J
Old Jan 1, 2008 | 01:05 PM
The cable is up higher.
You might need to remove the black bulster (Metal thing). to see the cable.
Old Jan 1, 2008 | 01:50 PM
jds850's Avatar
Tech,
Thanks found it and adjusted it for now but it appears that the cable is broken.
Thanks
J
Old Jan 1, 2008 | 01:55 PM
Did it move at all?
If not check the handle setup in the dash.
Pull the 2 temp ***** off.
Then slide the radio out and push the black part of the control for the A/C out.'
Then there is screws holding the back part to the dash. Remove the screws and check out the movement of the arms.
pete8475
Jan 31, 2025 01:06 AM
geo
Oct 27, 2010 07:11 PM
Ghost Brick
Sep 19, 2010 10:26 PM
Ghost Brick
Sep 18, 2010 03:14 AM
Ocotillo
Apr 21, 2005 04:42 PM
