Secondary Air Intake???
Old Dec 31, 2007 | 08:04 PM
jtvrba's Avatar
Default Secondary Air Intake???
Hey,
I have this persistent problem with my check enging light popping up for the "secondary air intake failure" I think the code is PO401 or PO402.
I replaced a few vacuum hoses because of dry rotting hoping that would fix the problem but the code continues to come back. I haven't notice any real change in the car but I wanna get rid of whatever is causing this.
Any suggestions would be much appreaciated...
Old Jan 1, 2008 | 09:24 AM
Default RE: Secondary Air Intake???
You will need to replace the air pump and valve on the back of the motor to get the code to stop.
Old Jan 1, 2008 | 02:20 PM
rob960's Avatar
I don't know if the 850 is the same as the 960, but when I got a code for the secondary air, I pulled the hose from the block to the EGR Valve. I then sprayed it (saturated it more like) with PB Blaster and it freed up the valve and no codes!
Air Defender
Jul 21, 2011 12:23 AM
heybuddy
Mar 2, 2009 08:12 PM
rquinonez32
Sep 30, 2008 02:08 PM
tom1568
Dec 21, 2005 09:36 PM
jrw
Nov 19, 2005 09:13 PM
