1995 850 turbo Blower / Resistor/ ECC ?
Old Apr 26, 2011 | 10:18 PM
dlaxdal's Avatar
Default 1995 850 turbo Blower / Resistor/ ECC ?
Blower would only blow hot air off and on . I changed the resistor and now nothing blows at all. The blower was working before I changed the resistor. I am wondering if the ECC ia not working anymore or could it still be the blower? Any thoughts? thx Also there are no lights on the ECC that usually light up. Any thoughts
Old Apr 29, 2011 | 11:01 AM
klausc's Avatar
Did you check the codes in B-1? Is the blower speed on AUTO or have you tried to slide it to the right to force the fan to turn on? There are 2 different resistors, I assume you got the more expensive version for the ECC. Check the fuses for the ECC and make sure they are OK.
Old Apr 29, 2011 | 09:03 PM
dlaxdal's Avatar
Default ECC fuses
The only fuse I saw was for the Blower motor. Where is the other fuse.
Thx. I changed the resistor and it the blower motor would run on high. Nothing on the ECC works at all. All the lights were burnt out if that means anything. Thx
Old Apr 30, 2011 | 11:07 AM
klausc's Avatar
Fuse 31 is for the 1-3 blower speeds. Check for electricity on both sides of the fuse. If none, it could be an overload relay for the X+.
Old Apr 30, 2011 | 05:21 PM
dlaxdal's Avatar
Default how to check fuse 31
How do i check fuse 31 are they expensive to replace? Thx for your help My daughter drove from Brandon manitoba to edmonton 12 hours with no fan but lots of heat still getting thru
Old May 1, 2011 | 11:20 AM
klausc's Avatar
Fuses are cheap, just go to any autoparts store. The fuse box might even have a couple of spares.
To check a fuse, pull it out and inspect the center for cracks or missing metal. A multimeter can check resistance from the two spade ends.
To check the fuse holder for electricity, use a test light. Just probe both ends where the fuse is inserted.
To check the ECC unit for electricity, just turn the vent dial and listen for the vents to move. The ECC unit can be pulled out of the dash, with a little effort and the radio out, so you can check the plugs in the back of the unit.
Old May 3, 2011 | 07:49 AM
dlaxdal's Avatar
OH ya Fuse #31. I checked it and it was fine. Ialso had to take it out so the fan would shut off. It must be the ECC
Old May 5, 2011 | 04:47 PM
dlaxdal's Avatar
Default sent out ECC unit to be rebuilt
so i stopped by an volvo repair shop in edmonton and they said they could run a scan for $130 and let me know the problem. \i sent away the ECC unit to be rebuilt by BBA reman for $100. I will try this and see what happens. \they said that sensors dcould be the problem also. Any thought? I had actually found a unit at the auto wrecker and \i had to leave town without buying and went back and the car had been crushed,what a waste of a solid body. Thats why i decided to send out the unit and see what happens.
Old May 6, 2011 | 10:27 AM
klausc's Avatar
You have a 1995, you could have checked the codes yourself before you sent the ECC unit off to be 'fixed'.
Old May 6, 2011 | 09:58 PM
dlaxdal's Avatar
how do you check the codes yourself. The bulbs were burnt out on the ecc unit. They were $6 a piece to replace. I appreciate the help. It is sent off for repair so I guess i will have to wait and see.
Old May 7, 2011 | 10:36 AM
klausc's Avatar
This link shows how to check the tranny codes, but the same is true for the B-1 for the ECC unit. You cannot check the ECC codes until the unit is back in the car.
Volvospeed
There are several online sites that have all of the codes explained.
Old May 8, 2011 | 07:43 PM
dlaxdal's Avatar
Thx i appreciate the help and it is always good to learn something new.
Old May 9, 2011 | 01:34 PM
dlaxdal's Avatar
Default ECC unit returned with no issues
BBA called todday and said they could not find anything wrong with the ECC unit and it would have to be tested in teh car. What and where are the sensors in the car that may be bad. Also what codes should i be looking for ? thx
Old May 10, 2011 | 09:08 AM
dlaxdal's Avatar
I did not see the B-1 code on the link you sent me. Where do i find that informatiom. It talks about using A-1 on the car by the washer fluid. What code am i looking for with the ECC
Old May 10, 2011 | 10:18 AM
klausc's Avatar
What I pointed you to was a description on how to use the probe. Plug the prob into B-1, and look at alll of the codes writing each series of 3 numbers down. Then erase them. Those codes that do not erase should be examined.
Here is a list of all of the codes:
http://www.matthewsvolvosite.com/vol...trouble-codes/
Old May 10, 2011 | 11:53 AM
dlaxdal's Avatar
Default B-1 codes
great thx I will try when I get the car this weekend. I really appreciate the time to repsond.
Old May 13, 2011 | 11:38 PM
  #17
dlaxdal's Avatar
Default It was the ECC assembly
Took the car to Mr Volvo in Calgary alberta and they had a used ECC assembly and it works great now. What a pain in the ****
Old May 14, 2011 | 09:44 AM
  #18
vjaneczko's Avatar
At last it's over - for now
jmallie
Sep 17, 2009 09:47 AM
Chupa517
Apr 3, 2009 05:58 PM
autoxray
Jan 4, 2009 07:03 PM
slowrider06
Dec 23, 2008 03:27 PM
MI_Marcus
Oct 21, 2008 04:14 PM
