1994 850 glt wagon doesn't want to go
Old Aug 15, 2011 | 08:23 PM
jgh's Avatar
jgh
Default 1994 850 glt wagon doesn't want to go
SOMETIMES-hot or cold weather or after driving for a while car just won't start. Cranks and cranks until the battery dies. The next day it starts right up. chck engine, abs, trac lights are on intermittently. A-2 code 4-1-1, and A-3 codes 3-1-4, 1-4-1, 1-4-2. Has in past had slow shifting from gear to gear, and a little rough idling, these things come and go. Had the car for 14 years and now that I want to get rid of it it starts throwing tantrums. I just want it to start every time so I can sell it. It has 130000 and is used 2 or 3 times a week, and has had fairly regular maintenance, I guess, and timing belt, serpentine belt(s), fuel pump, various hoses and brake jobs as needed. Took it to the shop, and of course it started every time for them, they kept it for a day testing regularly and found no problem but charged me a hefty sum anyway so that's it. I'm not spending any more on this beast. How can I fix this problem myself, please, ANYBODY?! JGH columbus ohio
Old Aug 15, 2011 | 11:00 PM
Henry10's Avatar
Fuel pump or its relay?? Search this forum for these.
Old Aug 17, 2011 | 03:37 PM
jgh's Avatar
jgh
new fuel pump, hear it working, code 4-1-1 on A-2, waiting for manual.
Old Aug 17, 2011 | 07:32 PM
jgh's Avatar
jgh
Default throttle position sensor
jetronic lh3.2
electrical system A-6 fault code 4-1-1 throttle position sensor absent or faulty
fuel system A-2 fault code 4-1-1 throttle position sensor absent
Old Aug 19, 2011 | 08:29 PM
jgh's Avatar
jgh
Default this problem solved
this problem solved-fuel pump relay replaced
parbar
Jun 19, 2013 07:18 PM
CaseyB
Nov 23, 2012 06:19 AM
blondetamadrummer
Aug 22, 2009 12:25 AM
Muskoka
Jan 1, 2009 08:09 AM
GeneAlexander
Nov 16, 2006 06:59 PM
