1996 850 volvo running light fuse
Old Sep 25, 2010 | 05:26 PM
blackgsxr05's Avatar
Default 1996 850 volvo running light fuse
the daytime running lights are not working, i checked the bulbs W/the test light something shorted, checked all fuses under the hood, still good, any other fuses? what did i do wrong?
Old Sep 25, 2010 | 07:26 PM
Do they work in the headlight position?
Maybe the headlight switch is also bad.
Old Sep 25, 2010 | 07:50 PM
headlights work. shorted out running lights in rear. any other fuses? under hood?
Old Sep 25, 2010 | 07:59 PM
Oh do you mean parking lights?
If so there is also a blue relay/box looking thing in the trunk on the drivers side. That is the bulb failure relay that might be doing it.
Old Sep 25, 2010 | 08:11 PM
i seen that did that relay go bad and is it alot of $ to fix
Old Sep 25, 2010 | 08:23 PM
I would check a local salvage yard first. To start I would unplug it and see if the fuse stops blowing. Also maybe unplug the front corner lights as well till the fuse does not blow. Then connect each thing till it blows.
Old Sep 25, 2010 | 08:39 PM
ok let me try that thanks
Old Sep 25, 2010 | 08:42 PM
Good luck! Let me know how you make out.
Old Sep 25, 2010 | 09:57 PM
went and tryed it didnt work i unpluged and pluged it back in and the same thing anything else you may can let me know im lost
Old Sep 25, 2010 | 10:37 PM
Did you unplug all 4 light assembly's?
Old Sep 25, 2010 | 10:42 PM
all 4 light assembly where im lost thanks
Old Sep 26, 2010 | 07:01 AM
Unplug the plugs to the rear taillights and front corner lights.
Old Sep 26, 2010 | 09:43 AM
will try today let u know thanks
AlexCurran1
Jun 22, 2011 12:15 AM
collslee
Mar 2, 2011 05:19 PM
briguy1960
Nov 10, 2010 06:40 AM
Nataku
May 10, 2009 04:39 PM
mischief4l
Sep 2, 2008 07:13 PM
