1996 850R revving on its own
Old May 14, 2009 | 06:51 PM
  #21
But does the pressure drop when it messes up?
Old May 16, 2009 | 11:41 AM
  #22
maddox's Avatar
Tech,
I haven't checked the fuel pressure yet. Is normal pressure supposed to be between 38 - 42 PSI?
Thanks
Old May 16, 2009 | 08:57 PM
  #23
Yes close to that.
Old May 18, 2009 | 02:44 AM
  #24
jikispqr's Avatar
Mine also was revving and car also failed to start and it turned out that it was PNP. https://volvoforums.com/forum/sho...t=29432&page=2
Old Jun 14, 2009 | 12:06 PM
  #25
maddox's Avatar
Tech,
I finally found a fitting(similar to a tire pressure valve) to check the fuel pressure with. At idle it is 38 PSI. I cannot find a fitting that would screw onto the fuel rail to leave on there so when the car does stall again, I can see what the fuel pressure is. Any ideas where to get such a valve? Also is has stalled a couple of times since the last post. It also apprears to only happen when it is 82-84 degrees ambient or warmer outside temperature with high humdity.
Thanks in advance for your help.
Old Jun 14, 2009 | 09:39 PM
  #26
nonsense619's Avatar
you can borrow an actual fuel pressure gauge at autozone i think.but just going on the fact about the temperature and humidity i would look at the fuel pump relay.i know if the solder points are cracked like alot of them are then heat and humidity might affect it.my friend was having same issue with his acura in high temp/humidity,and a new relay solved the problem completly.good luck
Old Jun 19, 2009 | 10:15 AM
  #27
maddox's Avatar
The fuel pump relay was already replaced 6 weeks ago. I will check with Autozone though.
Tech - Do you know where to get a fitting for the fuel rail?
Thanks
Old Jun 19, 2009 | 07:06 PM
  #28
Most generic fuel pressure guages already have the connection on the guage to connect to the fuel rail.
sauer9
Jun 12, 2023 04:48 AM
Autoflock
Apr 29, 2009 09:19 PM
Bruce Wayne
Apr 3, 2009 11:10 PM
benisasome101
Nov 25, 2008 07:08 AM
robsb
May 24, 2008 02:36 PM
