1996 Volvo 850 fan/blower won't shut off
Old Aug 3, 2013 | 01:49 AM
mepammy's Avatar
Default 1996 Volvo 850 fan/blower won't shut off
hi -well I got the car home! Had just bought it and very soon noticed that every time I turned the car off, the blower remained on (for longer than I thought it should). Brought this to the attention of at least 4-5 people who witnessed this and said it was normal, but I still thought not. I was cleaning the car and had all the doors open -could still hear the fan on after about 45 mins. I went to turn on the car and the battery was dead (yet the blower was still running!). Called AAA battery service. By the time the guy arrived, the blower had stopped. Battery tested bad, no issues with anything drawing from the battery. But I suspected that since the blower had shut off...that it wouldn't test as drawing from the battery. New battery installed. Drove 15+ miles and back at home, shut off the car and the blower remained running. After 45 mins...I tried to think of something I could do because I thought if this thing kept running, it may run down the new battery by the morning. So I started the car and then turn it off right away...and the blower cut off (phew!). I've read an old thread related to this issue, so I have some clues that it may be a relay or resistor? I'd appreciate any suggestions/advice -please and thanks !!
Pam
Old Aug 3, 2013 | 12:41 PM
1995Volvo850's Avatar
Pam
When you say "blower" are you referring to the blower for the climate control or the fan in the front of the car that sucks air through the condenser, intercooler, radiator, etc?
1995Volvo850
Old Aug 3, 2013 | 04:11 PM
Usually resistor or relay at the fuse box.
Old Aug 3, 2013 | 06:29 PM
Old Aug 3, 2013 | 11:08 PM
mepammy's Avatar
1995Volvo850
Fan in front. Meanwhile, we disconnected it so that it wouldn't run down the battery
Old Aug 3, 2013 | 11:11 PM
Likely a bad ECT:
mepammy's Avatar
tks much for the info! It apparently is the fan so I shouldn't have added blower!
Old Aug 3, 2013 | 11:13 PM
mepammy's Avatar
okok but wouldn't I be getting a dummy light on that?
Engine cooling fan is under the hood.
Blower motor is in the dash & helps cool the cabin climate.
Old Aug 3, 2013 | 11:29 PM
mepammy's Avatar
very excellent, tks so much! Might as well replace the thermostat at the same time? Now to me, it seems as though the car is running hotter than it should. The temp gauge has been steady at slightly above midway (should be slightly lower). And I thought I've heard some gurgling/boiling more than I should. What would I expect if both the ECT and thermostat are bad....wouldn't the fan not run at all? I don't believe the fan is running that long to cool things down. Do you know how long the fan should normally be running after shutting off the car? tks!
Old Aug 3, 2013 | 11:48 PM
Normal operation is pretty much the same for turbo, non turbo, modified .... it should sit at about 3 O clock.
If either the relay or temp sensor is bad it might overheat. If both are bad it SHOULD overheat.
If you see a gurgling or bubbling in the expansion tank on the passenger fender you might have a bad head gasket and you need to address that as soon as possible. Left as is it will get worse and can get to the point it costs you an engine should it overheat someplace you can't get out of traffic soon enough.
There are kits you can get from auto parts stores to check to see if there is exhaust (hydro carbons) in the coolant. It's a very quick and easy test and the tool is a loaner, the fluid you need to buy.
My radiator blower motor in the front of the car turns off when I shut the car off.
Attached Thumbnails 1996 Volvo 850 fan/blower won't shut off-headgasket-tester.jpg
Old Aug 8, 2013 | 09:02 PM
mepammy's Avatar
Thanks again for all the info! And it was....the relay switch! Easy fix. Having A/C fixed (hopefully) on Sat. Not liking some loud noises the car is making after I drive it 200 miles.
Old Sep 13, 2013 | 04:41 PM
theman's Avatar
I'm suffering same now - my preggy wife is not a happy woman right now.
D'you have/remember the relay part # by chance? And where is it, under the hood next to the fuses?
Thx.
pdx
Oct 30, 2012 03:46 PM
vvod
Nov 18, 2009 07:30 PM
Pyrate
Jun 15, 2009 02:17 PM
neill1223
Dec 21, 2008 10:15 PM
01v70xc
Dec 16, 2004 10:11 PM
