1997 850—Dipstick Snapped in Reservoir
Old Feb 14, 2013 | 12:34 PM
arthur.porrello's Avatar
Default 1997 850—Dipstick Snapped in Reservoir
Mechanically Inclined:
I was changing oil in a 1997 Volvo 850 today, and just as I was finishing up the job, the dipstick snapped in the reservoir. It's pretty far down the tube, about an inch and a half or two. I didn't want to mess with it in fear that I would make it worse.
I really need help with this. I do not want that dipstick to be stuck forever. Does anyone have any tips on how I can get this out? I've seen forums that suggest glue and a stick or sucking the dipstick out. But these do not seem plausible to me. Can I take it out by dropping the pan? Can I remove the dipstick reservoir?
Thank you for any suggestions.
Old Feb 14, 2013 | 12:41 PM
Hi Arthur and welcome to the site.
I'm not sure what you mean by reservoir??? If you mean dip stick tube, you can pull the tube by pulling 1 bolt under the intake manifold then pulling the entire tube out. The bolt is a 12 mm and can be reached from up top. Some go at it from below but I think it's harder from there.
Old Feb 15, 2013 | 02:06 AM
silver ghost's Avatar
I second that or if you have a very small pair needle nose pliers that might fit into the tube should work to.
Old Feb 15, 2013 | 12:02 PM
MattyXXL's Avatar
If you pull the tube off you can push the dipstick out from the bottom it sticks out about 4 inches after the tube
rbunce
Mar 7, 2016 06:41 AM
bcolins
2001-2013 model year V70
Oct 28, 2013 10:55 AM
98_V70_T5
Jul 1, 2012 11:41 AM
redrex
Nov 10, 2011 12:39 PM
freshy
Sep 13, 2011 05:59 AM
