1997 850R ABS/Trac light on
Old Jan 12, 2013 | 08:19 PM
jbuck's Avatar
Default 1997 850R ABS/Trac light on
Recently sent my ABS module in to have reconditioned. Got it back today and lights still on and speedometer does not work. New rotors and pads cars stops perfectly. What else could it be?
Old Jan 12, 2013 | 09:31 PM
Wheel speed sensor ?? Was it the ABS or the Tracks light that was on
Attached Thumbnails 1997 850R ABS/Trac light on-wheel-speed-sensor.jpg   1997 850R ABS/Trac light on-instrument-idiot-lights-right-side.jpg
Old Jan 12, 2013 | 11:11 PM
jbuck's Avatar
Both lights are on, my code reader does not pull any codes for ABS. Is that normal?
Old Jan 13, 2013 | 12:48 AM
Where did you send it to be rebuilt?
Old Jan 13, 2013 | 11:24 AM
jbuck's Avatar
This is the company that did the rebuild.
BBA reman. ABS, ecu's, throttle bodies, air mass meters, and catalytic converters
Old Jan 13, 2013 | 11:54 AM
Oh, I've only dealt with http://midwest-abs.com/ . Very affordable and only does the Volvo units I believe.
Read a little on that site. I think the car has to be driven a few drive cycles sometimes to clear the code.
Old Jan 13, 2013 | 09:10 PM
On a 97 you would not be able to pull ABS codes with the average code reader. It would take a more expensive unit like the dealer or an independent shop that has shelled out a few grand.
That's the nice thing about the '95's and earlier you can get them with the under hood diagnostic panel.
Old Jan 14, 2013 | 10:50 AM
MattyXXL's Avatar
As RS said yoou should only go with Midwest... Midwest has done 3 modules for me and they are a hell of alot cheaper than BBA. Plus Matt guarantees his work FOR LIFE!!..
Email matt and explain to him what the issue is and he should be able to point youin the right direction..
MidwestModules@gmail.com
gabyman97596
Dec 23, 2010 08:59 AM
gabyman97596
Apr 23, 2009 07:20 PM
mcj
Sep 13, 2006 08:21 PM
Lawbrum319
Jul 14, 2006 10:30 PM
850GLTWAGON
Mar 24, 2006 09:14 PM
