ABS And TRac light on!!!
Old Dec 23, 2010 | 08:36 AM
gabyman97596's Avatar
Default ABS And TRac light on!!!
So both lights and the CEL has been on for a while and the code is p1550 I think is related to tthe abs and trac, BUt yesterday when changing the front pads i saw that one of the cables to the speed sensor was broken. So i knew that has to be the problem I put it back togueter and it was ok but Do i have to go to a scanner device to clear the codes I tried yesterday disconnecting the battery but no luck!!
Old Dec 23, 2010 | 08:49 AM
jks2's Avatar
Easiest thing to do is stop by Autozone. They have readers and they can read and clear your codes.
Old Dec 23, 2010 | 08:59 AM
i have a reader and before i knew the connector was bad it throw the code p1550. I guess is related to the abs and trac. i did repair the cable that was broken from the sensor. I think i have to a place so they can clear it or check if something else is bad.
jbuck
Jan 14, 2013 10:50 AM
dragonwingvolvoc70
Aug 22, 2011 08:00 AM
gabyman97596
Apr 23, 2009 07:20 PM
mcj
Sep 13, 2006 08:21 PM
Lawbrum319
Jul 14, 2006 10:30 PM
