Check engine,abs trac light on????
Old Apr 20, 2009 | 04:44 PM
gabyman97596's Avatar
Question Check engine,abs trac light on????
1999 S80 2.9.Ok i know the check engine is for the the o2 sensor that is on the way. jjust ordered them, its only one code bank 2 something.. But recently the abs and the trac light are on i dont wanna take the car to a dealer just to check that. i think i've seen on past posts that i cant find that when both lights are on at the same time its because the abs control module is bad???? Just want a opinion from you guys before i take it to an expert to check it?????
Old Apr 20, 2009 | 06:51 PM
Most likely the module is bad. You can remove it and have it rebuilt for about $100.00
Old Apr 20, 2009 | 08:25 PM
Ohhh thanks... and where is the abs module located near the abs pump?????and do i need a mechanic to put that or i can do do it myself, and after i put it new will it reset the lights by itself or it will need and scanner for that thanks in advanced
Old Apr 20, 2009 | 08:29 PM
Check this link.
This will tell you how to do it.
Old Apr 20, 2009 | 08:31 PM
Where's the link???
Old Apr 21, 2009 | 07:08 PM
Sorry Brain Fart!!!
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Old Apr 21, 2009 | 08:34 PM
75ohm's Avatar
E5 is your friend.
Old Apr 23, 2009 | 06:12 PM
Thanks !tech! I bought a rebuilded one its working and no funny lights on my dash thanks again for making me save a couple of hundreds lol
Old Apr 23, 2009 | 07:20 PM
Glad it is all well now.
dragonwingvolvoc70
Aug 22, 2011 08:00 AM
gabyman97596
Dec 23, 2010 08:59 AM
llama_of_doom
Aug 23, 2007 09:52 PM
mcj
Sep 13, 2006 08:21 PM
Lawbrum319
Jul 14, 2006 10:30 PM
