2 ? / AC and Clicking noise
Old Apr 17, 2009 | 06:43 PM
Chebucto's Avatar
Default 2 ? / AC and Clicking noise
Hi guys, I have two questions tonight. I ready to check out my AC for the summer on my 850 Turbo Wagon. I checked out the compressor and clutch does not seem to click in. I dont know if the system is charged or not as I just bought it in Dec. Can you give me a starting point of things to check. 2nd question. I am getting a periodical loud clicking noise from under the distributor Hood. It seems to come and go....sounds electrical. any ideas of what to look for?
I taking it to my Do it yourself garage tomorrow so I was hoping for some ideas to look for.
Thanks in advance.
Chebucto
Old Apr 17, 2009 | 11:25 PM
bestharry's Avatar
For Air, there is a valve just behind the passenger side headlight under the hood on one of the AC lines. Just take the plastic cap off and press the nipple thingy in the middle (its liek the valve o tires) adn that will tell you if you have some pressure in your system or not. Now this clicking noise you mentioned can be from the AC compressor ad it might be kicking in intermittenly if your system is just little low on freon.
Old Apr 18, 2009 | 12:31 AM
cj351stang's Avatar
Clicking noise is probably the valve on the driver's side of your fan, bolted to the fan shroud. Its part of your evap system.
Old Apr 18, 2009 | 08:17 PM
Chebucto's Avatar
I rechecked where the sound was, and yes its coming from I suspect is the EGR Controller....it has two vacuum hoses to it...now the question is, is it suppose to multi click like that every 3 to four min.
Chebucto
Old Apr 18, 2009 | 09:29 PM
That should be the evap valve. Is it mounted in a rubber grommet?
If so yes that is normal after the car warms up.
Old Apr 18, 2009 | 10:07 PM
Chebucto's Avatar
Thanks a ton, saves me time to take apart and clean or replace.
Chebucto
Old Apr 18, 2009 | 10:13 PM
Your Welcome
Lanabanana
Jul 6, 2013 10:22 PM
Gardenhands
Jun 20, 2012 12:20 PM
iceracer46
Nov 8, 2011 09:32 PM
amikuk
Mar 12, 2008 01:04 PM
thejman
Jun 7, 2006 11:49 PM
