VALVE LIKE CLICKING NOISE FROM ENGINE
Old Jun 7, 2006 | 09:01 PM
thejman's Avatar
Default VALVE LIKE CLICKING NOISE FROM ENGINE
Hi i have this valve like noise like metal hitting metal ticking noise coming from my engine, it goes faster the faster i rev the engine its there when i,m not accelerating and there when the engine is at idle. i think it has gotten loader in the last month its there for the last couple of month,
i,m driving a volvo s40 2001 with 52k on the clock serviced 3 months ago.
one of my friend told me it could be a bad exhaust valve or fuel valve on one of the cylinders is that true?
cause i know thats expensive to get fixed
please help jeff
Old Jun 7, 2006 | 09:17 PM
Default RE: VALVE LIKE CLICKING NOISE FROM ENGINE
Have the oil pressure checked it could be bad Oil Pan O-rings.
Old Jun 7, 2006 | 09:32 PM
thejman's Avatar
Tech it sounds like it coming from the top left side of the engine if you where standing over it.
would that be where the oil pan O ring is
Old Jun 7, 2006 | 09:49 PM
The o-rings are in the bottom of the engine.
But they help Hold oil pressure when the car is running.
If they are bad basically you will have low oil pressure.
I also believe the left side(When you look straight at the enigne) is also the end of the line for the oil before it goes to the bottom of the engine.
Old Jun 7, 2006 | 09:55 PM
thejman's Avatar
Would the wrong engine oil cause this because you said use 10 w 30 ya?
i think i put in a litre of 10w 40 over 3 months ago would that have any impact i,m living in ireland aswell that would'nt have any effect on what ye use in usa would be different to here
Old Jun 7, 2006 | 10:00 PM
No that would not affect at all.
If you want to see what it takes to do it I made a post on it.
If will be a little different for you because you have a S40. Yours will be a little easier.
Click here
https://volvoforums.com/m_6169/tm.htm
Old Jun 7, 2006 | 10:15 PM
thejman's Avatar
It looks easy there but its a dirty job i don't think i'd try it not really a mechanic,
plus there is'nt a 100% chance that it is a bad O ring is there
i'l bring it to my local volvo dealers tomorrow and see what they say they say the sound is and i'l get back to ya tommorow
thanks
tech
Old Jun 7, 2006 | 11:49 PM
Sounds good.
peace562
Feb 20, 2015 07:39 PM
Lanabanana
Jul 6, 2013 10:22 PM
victory
Jan 30, 2009 06:14 PM
fredbyte
Jul 22, 2008 04:21 PM
Bobd207s
Oct 24, 2006 11:55 PM
