3 small Covers on back of Turbo engine
Old Apr 13, 2011 | 10:47 PM
91shelby's Avatar
Default 3 small Covers on back of Turbo engine
There are 3 small covers on the back of the engine just above the oil pan seam, are these related to the cooling jets? I ask because my middle cover is starting to leak.
Old Apr 14, 2011 | 08:56 AM
boxpin's Avatar
When was the last time you changed your PCV? I will spare you the horror story but my last engine leaked like a siv. Bottom line, the rings were shot and I had no compression but what really was happening is the blow by was so bad it pressurized the block and I sprung leaks along the actual mid block and pan. If yours in the cover count yourself lucky, easy to address.
This is my story, dont know if it relates to what your seeing but I would change that PCV if you havent.
Side note: Oil cooling is not present on N/A engines but is on Turbo engines and exits the oil pan on the front pully side of the engine.
Old Apr 14, 2011 | 10:05 AM
One of those covers leaked on our S70, it was a good leak. I ordered the kit, they don't sell 1 all 3 come in the kit. I replaced 1 and not the other 2 so I have 2 of those if you need 1, PM me.
The PCV system on our car was in bad shape when we got it. I replaced it about 4 months into our ownership because it was popping the oil dip stick out. We also had cam shaft seals leaking so I replaced all 4 of them as well.
I do believe that our clogged PCV system contributed greatly to our leaks.
Old Apr 14, 2011 | 03:59 PM
91shelby's Avatar
When i got the car the pcv was plugged i replaced it within a month of getting the car, but it attributed to a few leaks i have already fixed. i noticed oil drips on the back side of one cover, are they related to the oil injection though? RSPI ya i only need one ill send you a PM later
kstinmb
Jan 28, 2015 12:35 PM
thunderdan27
Jun 20, 2014 09:48 AM
geraldc70
Feb 2, 2014 07:42 PM
sparky32
Jul 15, 2011 05:51 PM
poor_red_neck
Jun 27, 2010 09:03 PM
