300k on my 850 turbo
Old Apr 7, 2011 | 10:15 PM
jasenklems's Avatar
Default 300k on my 850 turbo
I have just recently bought a 94 850 turbo wagon it is an auto and I have a few problems for starters I have to replace the down pipe as it was modified in a back yard... It is causing a problem with fuel econ... the mileage counter broke at 259k but the speedo works and the horn doesnt work.. The abs light is on but the fuses are pulled for the system I put them in and the light stayed on and the traction light came on so I pulled the fuses again. I have to replace the suspension front and rear and I also have to replace the blower motor for my hvac system.... The car runs great no problems with the engine other than the down pipe and a tune up... the trans shifts a little harder than I think it should in sport.... thinking that I will do a filter and fluid change on it unless someone thinks that is not a good idea.....
any advice would be great as this is my first volvo......
Old Apr 7, 2011 | 10:20 PM
As for your hard shifting, probably the transmission mount.
Old Apr 7, 2011 | 10:31 PM
jasenklems's Avatar
thanks for the info will replace that as well but wouldnt it also shift harder in the econ mode as well
frankkk
Canada, Over Seas & Elsewhere
Sep 7, 2013 01:08 PM
mikeawd850
Sep 6, 2013 05:14 PM
Keith Tobberman
Sep 30, 2011 10:36 AM
Beemer2002
Jan 28, 2010 09:27 PM
1Gray760T
Nov 13, 2009 08:19 PM
