4th fan speed troubleshooting
Old Mar 25, 2008 | 05:17 PM
stecz's Avatar
Default 4th fan speed troubleshooting
My fan doens't work on the highest speed. The fuse is good and I purchases a new A/C fan switch thinking that was the problem. The fan still only works on the first three speeds. I bought the fan switch off of e-bay, so it may be bad also, but is there anything else that could be causing the problem?
John S.
93 850 GLT, manual A/C
Old Mar 25, 2008 | 06:51 PM
Ozark Lee's Avatar
Default RE: 4th fan speed troubleshooting
Chances are the max fan relay is bad. Fans speeds 1-3 run through the resistor pack, the max fan relay bypasses the relay pack altogether when you switch to position 4.
They usually fail the other way around - where speeds 1-3 don't work but 4 works just fine.
...Lee
Old Mar 26, 2008 | 06:51 AM
stecz's Avatar
Where is the relay located? under the hood by the fuses or under the dash somewhere?
Old Mar 28, 2008 | 06:01 AM
stecz's Avatar
I found the box of relays (right next to the fuses)... but which one is the fan? I switched around the 3 identical square relays and didn't change anything. The relay must be under the hood somewhere. I only have a Haynes manual (not even an owners manual) and it doesn't say what the relays are, just that some are under the hood and some under the dash...
I also didn't find any information on the web. There's a lot of info on fuel pump relays, but not any of the other relays....
Old Mar 28, 2008 | 09:49 AM
JPN's Avatar
JPN
I would check the fuse first; I could not locate speed-4 relay. The relay in the pic & manual is for the A/C so it may not be the one.
JPN
[IMG]local://upfiles/6892/C100CE8295BD44009782D85FCAF1D003.jpg[/IMG]
[IMG]local://upfiles/6892/E4ADF60B6952413999EAAD02B886F0A2.jpg[/IMG]
[IMG]local://upfiles/6892/F94142603695426DB2F8FFE63EBECAF1.jpg[/IMG]
Old Mar 28, 2008 | 10:21 AM
Ozark Lee's Avatar
The relay to the left in JPN's picture is the max fan relay. The one to the right is the A/C relay. Be sure to check fuse number 5, it provides power for fan speed number 4 only. Speeds 1-3 are fused via fuse number 31.
...Lee
Old Mar 28, 2008 | 09:50 PM
stecz's Avatar
The fuse is definitely good, I even swapped it with a known good one from another circuit....
Thanks for the info on the relay, I'll check it out...
Old Mar 29, 2008 | 06:12 AM
Bigtrev's Avatar
Try the blower fan resistor on the passenger side of car under glove box.
arlovarri
Jul 6, 2006 09:21 PM
arlovarri
Jul 6, 2006 06:08 PM
sherriel123
Jul 22, 2005 09:40 PM
parrym
Nov 7, 2004 11:30 AM
otguk
Oct 2, 2004 07:59 AM
