850 atrting problem
Old Jan 18, 2010 | 12:52 PM
TONY12340's Avatar
Default 850 atrting problem
hi guys
i got into my "93 850 this morning and it would nt start.
turns over but nothing
the battery has now gone flat after so many failed attempts..
spoke to a friend of mine who said its the sensor in the exhaust??
any ideas??
Old Jan 18, 2010 | 04:45 PM
s_moneh's Avatar
could be anything to be honest
fuel pump
fuel relay
crankshaft sensor
camshaft sensor
are u getting spark?
are u getting fuel?
maybe u tripped the immobilizer if u even have one on your 93
anythings honestly possible
Old Jan 19, 2010 | 10:15 PM
a_red_850's Avatar
First: Check and make sure you have spark, take out a spark plug, put the wire on it and hold it to your valve cover or your core support and turn it over, see if its sparking..
Second: If you do have spark then it is likely a fueling issue, check fuses for your fuel system, or to make it simple, look at the tips of the spark plugs to see if they are wet. If they are soaked, leave them out and crank the engine once or twice, then leave the holes open and close the hood for a while to air them out, dry off plugs, then try again. If it IS getting fuel, it may just be flooded somehow.
Old Jan 20, 2010 | 01:26 AM
harris777's Avatar
Many of these cars suffer difficulties starting, especially when the engine is only run for a short time then switched off, and an attempt is then made to restart it. It is inadviseable to start any car with a catalytic converter in order to move it a short distance. The ECU's cold running sequence (which is designed to protect the catalytic converter from unburned petrol) cannot cope with this and having detected too much raw fuel in the xhaust, will shut the engine down.
Another cause, especially on the 850 models, is that the hydraulic tappets do not close properly when the engine is switched off. Oil gets behind them stopping them from closing fully. This means there is no or little compression in the cylinder when there is an attempt to start the engine again. One cure is to remove the plugs and squirt engine oil into each cylinder then replace the plugs and start the engine. The oil helps seal any gaps under the valves and give adequate compression in the cylinders.
Another cure is to use Mobil 1 engine oil all the time. This is thinner than other oils and will allow the tappets to close properly. If you change to Mobil 1 oil be sure to run the engine at 3,000rpm for about 20 minutes to ensure the oil gets into all the small channels in the engine.
______________________________________________
CO2 Generator
wall décor for girls room
s70_t5_1999
Jan 22, 2010 11:53 PM
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
