850 Factory Upgrade
Old Apr 2, 2013 | 09:00 AM
97black850's Avatar
Default 850 Factory Upgrade
I'm looking at upgrading the factory system in a 94 850. I am looking at infinity reference series. Just wanted some thoughts/tips
Old Jun 21, 2013 | 11:40 PM
Moved to 850 area.
Old Jun 22, 2013 | 04:50 PM
rrochell8's Avatar
Most car speakers that you buy will be 4 ohm. Most of the speakers in your Volvo will be 8 ohm. Usually the front doors are 4 ohm, but all the rest are will be 8 ohm. If you choose to run 4 ohms all around you will be undue strain on the built in amps of your radio and you will lose a lot of sound as well. They will sound weak. You could stop running your rear door speakers and put 4 ohms in the shelf and then stop running your dash speakers and put 4 ohms in the front doors. Or you do as I have done and search long and hard and find 8 ohm speakers that will work.
Old Jun 22, 2013 | 05:07 PM
Why do you want to upgrade the stereo? If you get a nice Premium Sound System out of a newer 850, S70 or 960, the sound will be great.
Old Jun 22, 2013 | 10:25 PM
slimflex2's Avatar
l need one Robert. l need the tape with cd player that says premium sound plus one rear speaker. is there anyway you can get me one?
Old Jun 23, 2013 | 12:20 AM
97black850's Avatar
RSPI- I did put the premium in it, but most of the speakers crackle and sound bad. The two on the dash don't work at all. One in the rear deck works, but the other one does not. I have two in the rear doors that are out of a wagon that are decent and the two in the front door work.
rrochell8- What speakers did you end up using?
97black850
Apr 5, 2013 06:03 PM
T5-Rennen
Jan 22, 2013 12:58 AM
gabyman97596
Apr 24, 2009 06:58 PM
rgs4x
Mar 27, 2007 02:13 PM
S70driver
May 15, 2006 05:02 PM
