850 headlight replacement
Old Jan 3, 2005 | 09:52 PM
spike's Avatar
Default 850 headlight replacement
I have a 1995 850 GLT. I think I can figure this out, but wanted to ask before I broke something. I located the plastic circular casing that houses the low beams, as well as the one that houses the high beams.
I can also see that there are tight tabs holding in the lights.
1 - how do I get these tabs loose without breaking them?
2 - I assume once I do that, the light will just pop out with a tug.
Can someone verify this is what I need to do? Thanks!
Old Jan 4, 2005 | 12:29 AM
Default RE: 850 headlight replacement
Are you just trying to replace the headlight bulb?If so once you remove the plastic cover there should either a metal clip.If the bulb is all metal then there should be a metal clip that needs to be released.If the bulb looks like it is all plastic.Then the bulb just turns to be released.
Old Jan 4, 2005 | 06:46 PM
spike's Avatar
Thanks. Job complete, new sylvania silverstar lamps installed!
Old Jan 4, 2005 | 08:14 PM
No problem anytime
slynchy
Apr 4, 2016 07:37 AM
Kiss4aFrog
Jan 19, 2012 12:54 PM
Peter1234
Nov 23, 2010 01:19 PM
kevinmcgrath
Nov 24, 2004 07:00 PM
kevinmcgrath
Nov 24, 2004 06:57 PM
